Freeze Plugs
240240
Anyone know where to get freeze plugs for the rb20 motor?
Joe
KUILLIN_DRIFTER i removed your post because you were linking to another site and didnt even know what the part was.
a freeze plug is meant to pop out incase the liquid in the block freezes (i.e. coolant freezing during winter). its to relieve pressure so the block dosent crack.
240 240, i bet if you take the plugs into a nissan dealer they can match them.
240240
if one of these were bad or popped for some reason or another, it would cause overheating correct....
Joe
not really..only if its leaking
Carl H
240240 wrote:if one of these were bad or popped for some reason or another, it would cause overheating correct....
yes if the motor was running and one were to blow out or die then it would over heat due to the lack of coolant in the motor.
240240
I know that I have a leak somewhere and it looks to be around the freeze plug but Ill have to pull my starter off to tell.
I will let you guys know
HaXoRsMoBiLe
Car: 2x 90' hatches KAT and RB20
you ppl dont know much about motors, lol Freeze plugs are used to plug up the holes from casting the motor, not if it overheats/freezes, if that happened they would need to be replaces way too often
TheOne
Car: 93 240sx FB
http://www.gandjtire.com/radiator.htm
Freeze plugs (also called "blind" or "expansion core" plugs) are small steel plugs used to seal the holes in the engine block and head made in casting. They expand and flatten as they are driven into place, and make a tight seal. These are designed to hold the pressure of the cooling system, but to pop out if the coolant in the block ever freezes.
Joe
HaXoRsMoBiLe wrote:you ppl dont know much about motors, lol Freeze plugs are used to plug up the holes from casting the motor, not if it overheats/freezes, if that happened they would need to be replaces way too often
haha k, we have no idea what were talking about.
DriftingisLame
Car: '91 240sx coupe, rb20det
Whatever man, we'll settle this at race wars!
