elwesso wrote:Just remember, why would the factory do certain things if it was detrimental to HP or gas mileage?
The screen on the intake before the MAF makes the flow more laminar so that the MAF gets an accurate reading.. The coolant going by the TB makes it so that the TB doesnt get gunked up as fast...
the coolant is to warm the TB with the motor in cold climates from what I've heard.
the screen is at the TB not anywhere within a foot of the MAF how would that effect it's readings?
Take your exhaust off and run open headers... at least it will sound cool.
custom exhaust is STUPID easy. as for intakes, I'm 90% sure u could make one of the titan intakes work. it's pretty basic of a setup imo and from what I've heard the new Xterra's can use the same intake and they're only a 4L v6 so I'd imagine the v8 pathy could VERY easily use one if at very least u need to slighty trim the piping to fit. so long u keep the diameter of the pipe AT THE MAF the same as stock (which most of the titan intake kits are) would be a good idea to keep readings accurate on velocity/amount of air.
2* timing makes a difference but not as much as say a programmer or even intake really imo. knowing how nissan likes to reuse parts I'd wager ur TB is the same as that on a titan, so u can even get a titan model TBS, THAT is the main time titan guys remove the screen from the TB. not just to remove it...
I have a titan, I have intake, TBS (screen removed) custom exhaust (headers are on order through a fugled group buy with never ending delays) and a programmer. so my truck has a few mods, and I have to say the single best bang for buck so far is the programmer, the bully dog power pup (what I have) can be used to add 2* timing to almost any later model nissan/infinity including altimas, titans, frontiers, xterras, Q56s, Maxima's really I don't know of any late models it CAN'T do the 2* on. and u don't need to lock it to the vehicle so u can do as many peoples rides as u can fine who want to pay u for it but for tuning well the ONLY custom tuning is UPREV... good luck
