Working with the rear muffler assembly is the most cost effective and weight saving mod you can make on a Q.
Find a dual in dual out straight thru Dynomax ULTRAFLOW.......the quiestest lowest backpressure [you can see straight thru each section] muffler made.Both the corporate Q have this ULTRAFLOW muffler held in place by Chrysler oval bands onto which have been welded the 4 oem mounting brackets/ears so it it supported in oem fashion .
http://www.dynomax.com/ultrafloss.stm
http://www.a-1performance.com/...3.htm
Look at 17280 [2 1/4"] or 17276 [2 1/2"] dual in dual out pipes
both under $200 in stainless steel, the welding straps and ears should make this an under $400 exhaust redesign.
17515 is a 2.5 dual in/out welded aluminum that cost only $125 but stainless at $60-$70 more is a better deal looks and life wise!
Please don't bother [waste you time] with any other muffler manufacturers JDM or domestric.
We have retrofitted and designed systems for dozens of Q45.
