ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Fri Mar 26, 2004 7:14 pm
The other day my car got broken into, so now my car is lighter by:1 passenger side window1 Apexi-SAFC1 JVC CD Player1 Bell Radar Detector
Seriously though, this does fit into technical, here's how.
I have 370cc injectors, and the SAFC was tuning -27% to compensate for the bigger injectors(I'm going turbo soon). Well, without the SAFC, my car wouldn't run right because it was running so rich. Here's what I did.
I cut a hole in the plastic intake pipe after the MAF, and played with the size until it was running right. I also, vaguelly tuned it using my air/fuel meter(yes, I know they're not that accurate, but they're better than nothing). Then, I put a "filter" over the hole to keep some dirt out.
Anyway, the car actually runs great now. You wouldn't even know there wasn't a fuel computer in it. This is just a temporary fix until I can afford some new fuel management.
I know WD has talked about using a similar "fuel management" as an alternative to a hacked MAF. Well, I guess I'm the guinne pig, and it definately does work. Although, I will have some real fuel management before my turbo goes on.
Mike
