Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sat Jul 09, 2005 6:58 pm
CHM:
It refers to the angle of the spring and shock assembly to the control arm. The more tilted it becomes, the less efficient it is. Thus lowering the effective spring rate (and thus wheel rate). Ideally, you'd have the sock and spring perpendiculat to the forces they are resisting (a good double wishbone is like this usually), but since the mcpherson strut design has flaws, they must tilt it back a bit and inwards to be able to dampen rear and sideways jounces...
Much like too wide a wheel with negative offset, lowering your effective wheel rate means you must incarese your spring rate to compensate, which results in other issues.
Use the T/C rods, not mis-aligned camber plates to adjust caster if you need it. The front suspension was designed with that part there to keep the caster where intended, you'll get your best resulst manipulating it for adjustment.
Also, seeking higher caster numbers just for their sake alone is folly. Much like persuing more static camber without taking into consideration the effect it has on the rest of the car (or in bounce, for that matter).
lastly, I like cheeze.
-Chet
