RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Sun Jan 04, 2004 6:25 pm
Unfortunately, I'm writing this thread in terms of experience, not second hand knowledge. I recently had all my stereo system taken away from me. I know that they wroke in for my sub, and eventually took my deck, amp and even my burnt CDs......
Anyway, I know that the only way they got in is through the hatch. I did it myself before, a couple times actually. I dont want to say how, to protect others, but I do want to share how to prevent this w/o destroying your car.
If you open your hatch, take the rear panel off and look to the right of the latch, you'll see a metal cable. This cable is the line you open when you lift the latch. Simply snip this cable off and you're set. This works for people with alarm systems too, unless the sensors are set on the cable, which isnt really possible....nevermind.
Doing this disables your trunk release latch. I know that it may be a problem, but you can always open your hatch using your keys. This way, they cant break into your car easy enough to steal whatever.
Just trying to help~!
PS - this suggestion should only be done at your own discretion, I am not responsible for any damages that you or your cars might encounter. >:)
-R
