DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Apr 23, 2003 9:46 pm
Sorry for stealing them out from under you...my car's been needing these for a while though. It just didn't have quite the kick that 100k cars have, and I maintain it pretty well. Plenum, TB are very clean. Temp sensors are new. All fluids are less than 1 yr old. Next on the list are the various harnesses and connectors that are all cracking, possibly even the main engine harness (dash removal required). If and when I get to 250k I'll replace the timing chains and also consider doing a valve job on the car too (or maybe just swap the engine). For day-to-day, the TCU is what really makes the car fun, since the ECU differences are are only felt at WOT. You can get a '93 TCU for about $100, based on others' experiences, and it will give you the 1st gear start. Apparently, it doesn't matter if the donor car has HICAS or not, but I think you need to make sure the TCS and active susp options are the same, and stick with CA or non-CA standards.
