Frame work repair shop in Virginia Beach?
WildeSkye
Car: 2010 Nissan Armada Titanium
We took our 2010 Nissan Armada to a repair shop and this is the Report from them!
STEERING/SUSPENSION
1)FRONT STRUTS/SHOCKS There is excessive amount of rust on the front and rear suspension, the Front Struts are falling apart
Recommendation: DUE TO AMOUNT OF RUST ON VEHICLE, WE WOULD NOT BE ABLE TO SERVICE SUSPENSION COMPONENTS
2)FRONT STEERING COMPONENTS:TIE RODS, SWAY BAR/LINKS/BUSHINGS Front Tie Rod Ends are too rusted to adjust after Strut replacement to perform the alignment
Recommendation: Remove and Replace both Inner and Outer Tie Rod Ends
We need to find a body shop that does work on auto frames in Virginia Beach! If anyone can give me a recommendation, that would be awesome, as I have no clue as to where to look!
Reason: Revise Title
macgiver
Before you go there , buy 10 cans of RUSToleum paint and a bag 'o dozen steel wool and paint that sucka so they won't come down on you for SO MUCH RUST :facepalm:
:lolling:
p.s. Lay off the SALT water taffy down thar :yesnod
