slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Sat Jul 30, 2005 12:30 pm
Hi there, I thought my '92 coupe was it pretty darn good structural shape, untill today. While changing the oil, I noticed that the passenger side frame rail was split! I sketched a quick drawing to illustrate(below). The side of the frame that is pulled away is the flat piece that has the tow hook attached. It seems the spot welds just broke loose, and it is pulled about 1.5" away from the box frame. It is seperated all the way back untill the two mating surfaces go from being vertical, to a horizontal 'lip' down tthe rest of the rail. WTF should I do now, if anything?
Two incidents come to mind:
I just autox my car last night and spun out in a corner... the car didn't leave the pavement. This was just a one-time ordeal, never had it on the track before.
Also this car was just transported on an open trailer across country. Maybe the movers pulled the tow hook too far to the side(strapping it down)
I thought about just pulling the two back together and putting two bolts in to keep them together(with support bracket/washers), maybe some JB weld also. I didn't *see* anything structural that attached: just the bumper and fender support, maybe battery tray.
Does this pose any serious problems? It doesn't look like it will continue to split.
Thanks,-Jamie
