!Zar! wrote:As I said before, if you look under a J-spec s-chassis, you won't find frame rails.
Really? Then why is a popular "J-spec s-chassis" mod a bolt-in/weld piece that connects the front and rear frame rails along one side of the car.
Not only are you spreading dis-information, but it is potentially dangerous mis-information. Every unibody car I have ever owned had some sort of frame rails (And believe me, I have owned a few). The difference is that on a full frame chassis, the body is a completely separate piece(s) that bolts to the frame.
For a reference, here is the part I mentioned.
http://www.rhdjapan.com/jdm-lo...50942If there was no frame rail whatsoever, then what, pray tell would this bolt to? Or is URAS some fly by night company that sells extensions for imaginary parts of cars?
