frame damage!
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
have any of you guys have any frame damage before? i have gotton into an accident and bented my fender frame on my passenger side, my center core is slanted a little back to my engine. and my battery was push back also my radiater crack somewhere (i wasnt able to find the crack). after i gotton into the accident my car was still able to drive home but then my fan is not spinning. i was wondering if it is still gonna be safe if i was to cut the bent peice off and weld it back to a new piece? i hope this is enough info on my car. i will post up some pix when i have time. thankz
Fenvy
Car: 2005 350Z Base 6MT
which fan is not spinning? the one behind your radiator, if stock, shoudl be spinning at all time since it is a clutch fan. if it is the one in front of the AC condensor, it doesn't turn on all the time.
240sxvaj
yea its the one behind the radiator. i can move it with my hand but then it will barely move. and my engine runs ok too. my engine is still in its correct place.
timmy76106
Car: 1995 Nissan 240SX
its always better to get it checked by a professional because where its bent in there might be a lot more damage than you think so i would recommend taking it to a body shop that pulls frames or a frame shop to see what the real damage is
240sxvaj
i took it to a body shop and they said it will still be possible to fix but then i am gonna have to cut the frame where it is bent cause even thoe they pull it, it will not be straight. so the guy at the body shop said he will just cut it and weld a whole new piece. he has the front clip straight japan (s-13) in stock so he gave me a price of $700. also i was wondering if he was to do the work, would my car run the same as usual?
timmy76106
it should because everything would be in the right place all the dimensions of the car would be exact or off by a few degrees but just enough for it to run good
180fan
Car: 89 fastback
eh, it'll never drive the same again. It'll be fine for a daily, but if you plan to make this a project car, I would suggest looking for a different car.
240sxvaj
THANKZ GUYZ!
meangreens14
Car: s14 red top sr PARTING OUT!!!
daily:2008 subaru impreza wagon(knightrider)
yes...i have unfortunatly expeienced fram damage and the car drives different...it just feels off..goes strait on thw highways, drifts fina either direction, but still feels different. as for replacing that part of the frame...um if its cut and welded, its never going to be strong like it was in the first place. but it'll still work..good luck!
240sxvaj
oh yea, where was your damage at on ur car? and what did you notice that was different when you drove your car?
Hijacker
Car: '92 240sx Convertible
'94 F-150
My frame has been tweaked before too. The shop I used charged $225 to get it back to square, but it was barely out of square, I only noticed it cause the caster on my passenger side front wheel was visibly off.
240sxvaj
hey guyz! here is some of the pixs i took not too long ago
Modified by 240sxvaj at 10:30 PM 10/11/2009
mrzabala
Car: 93 Nissan 240SX SE Hatch
Dam the front view is all I need to know to tell you to buy a clip and do a rhd conversion. You'll be JDM tyte.
sds14240sx
Car: 240sx
mrzabala wrote:Dam the front view is all I need to know to tell you to buy a clip and do a rhd conversion. You'll be JDM tyte.
+1 yup thats about it
240sxvaj
what do you guyz think, would it be able to get fix?
meangreens14
no way! thats the same spot my car has damage, but not nearly as bad as yours! damm man, what happend. when i had the incident with my car i simply hammerd (i think yours will require some major pulling though...just hook it up to a truck and have them go slowly till it at least remebles what it is supossed to look like. then hammer the rest by hand) it out on my own and bought some origin fenders to replace the badly dented metal one. again good luck!
mrzabala
240sxvaj wrote:what do you guyz think, would it be able to get fix?
LIKE I TYPED!!!!:
240sxvaj
oh yea, do u have any pix of your car when it was damage? if u do can u post it up. and im not gonna pull my car into its shape im gonna cut the broken piece off and then re-weld it from a new piece. do u still have your car ever since ur accident? did u feel any difference in it when it was fix? and i dont want to RHD my car, i just dont like it. idk y
240sxvaj
check out BEFORE AND AFTER PIX on my other topic (check out more topic posted by me)
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
sell the car or part it out and buy yourself another one, it is repairable but its not an expensive car, it is more cost effective to get another one you will be happier down the line. repaired cars, no matter how well repaired, will never be the same as a straight car that has not been in an accident. this is from experience.
240sxvaj
killablue240 wrote:sell the car or part it out and buy yourself another one, it is repairable but its not an expensive car, it is more cost effective to get another one you will be happier down the line. repaired cars, no matter how well repaired, will never be the same as a straight car that has not been in an accident. this is from experience.
CHECK THAT OUT, i didnt gave up on my car! and never will >>>> zerothread?id=221793
