DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Fri Jun 08, 2007 3:33 pm
Drain Coolant, Unbolt Dipstick and move to the side, Remove Intake, Remove Hotpipe, Unbolt DP from Elbow, Unclamp Turbo Oil Return Line from underneath, Unbolt Turbo Lines from Block, Unbolt the Manifold from Block, Then pull the entire Manifold/Turbo/Elbow Assembly out. Somtimes it helps to unbolt the Brake Cylinder and move it up some. Removing everything usually takes me 1 to 1.5 hours but ive done it quite a few times.
