Im replacing the fr. main seal on and im wondering if i got to lube it w oil or
not...ive heard some peeps do and some dont...wats up, if i do have to where do
i oil it, outside the rim of it?
you will be fine with the lube that is on it already, make sure to slide it on and then slide it a little bit off to make sure the lips are not folded over.
OM3GA wrote:you will be fine with the lube that is on it already, make sure to slide it on and then slide it a little bit off to make sure the lips are not folded over.
