240Clarke »
https://forums.nicoclub.com/240clarke-u198631.html
Wed Apr 04, 2012 6:41 am
This is a semi long read, and sort of all over the place. My apologies beforehand.
Car: S13 Coupe
Engine: CA18DET
So just installed my CA. Im using the stock FPR and a Walbro 255lph pump. Ive read on many forums the possibility of the stock fpr being overran with a upgraded fuel pump, but what are the symptoms of that? My engine got absolutely flooded. To the point where my turbo elbow is coated with fuel (newly rebuilt SR T25) and my oil smells like gas. If it was flooded enough, could those 2 be results?
I just ordered a Nismo Type A, hoping that solves the issue.
I failed to replace the rear main seal when I put the engine in (I literally replaced EVERYTHING on the motor, just idiot part on my behalf overlooking the rear main), and it leaks. Leaks a steady stream of gas/oil upon cranking and starting. I say gas/oil because the oil smells like gas and in a test to isolate what it was, it ignites easily. I will be replacing it this weekend. Im guessing the overabundance of flooding, (many attempts to start the car before it actually fired up), caused fuel to leak down in the oil? Either way, what is the easiest procedure to replace the rear main? Is it pulling the engine, or just dropping the transmission while its still in the car. Ive read of people doing both. And I will be replacing the oil pan gasket at the same time. Once again, could just unbolt the mounts and jack the engine up a few inches, or pull the motor set. Wanted to see what people found the least time consuming/easiest to do.
All help is appreciated, flaming me for not replacing the rear main when the engine was already out of the car wont help. Thanks guys.
