Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Jun 12, 2007 4:56 am
Pretty simple the fuel pump won't run or will run intermittently.
Rarely you might get into one of 3 modes [pump speeds] dropping out, as the 3 speeds are set by ecu from throttle load..............again a rarer situation.
Pump speed is set by voltage and volume and back pressure* ASSUMING all commutators are clean and functioning.
* The filter sock on input rarely get dirty/c;ogged enough to materially change suction resistance........................fuel density from blend and temperatre can change pump rpm as can resistance of copper winding = cold winter speed vs hot summer speed.
