FPCU Fried, Repairable? (Pics)
natsoundup
sent you an e-mail.
50 dollars plus an estimated 6 dollars ground shipping.
Lee
Update:
Its been fixed, and it works! $15 in parts.
guadofreak
Car: 1994 Q45t
Jesda wrote:Update:
Can you give us a break down of what exactly was done? This is a VERY nice relief!
I put 100 miles on it so far, and its working well. Parts were $15. Labor was a lot of tedious soldering. I didnt do the soldering of course, otherwise it would be in the garbage.
Parts:
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
911/Q45 wrote:Don't use WD40! It reacts with the black plastic at the base of the antenna and ruins the whole assembly.
That is for sure! Really, this stuff is bad. I have repaired one antenna, and lubricated the antenna on my second Q, and they both continue to work without WD-40.
Don't use WD-40 on almost anything - unless it is all metal & no paint. It contains chlorinated hydrocarbons (so do most carb cleaners and brake cleaners) which degrade most all (non-flourinated) plastics. Buy alternatives that say they are "non-chlorinated", they are becoming more common.
I used a white slicon lub on the coiled nylon part that pushes the mast up and down, works great. Did the same on the mast. After lowering and raising it I wiped off the excess.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks Jesda. Going into my gallery of G50 repairs.
