91QAZ »
https://forums.nicoclub.com/91qaz-u22978.html
Wed Feb 22, 2006 1:42 pm
Jay,
1. When jumpered (is that a word?), the FP definately hummed a tune - louder than with just the FPCU connected. 2. The car ran well after the underplenum job - I also installed a NICO ECU from Robert at the same time. I did get a little bit of stumbling under hard accel right after the underplenum job/ECU install - but it has not repeated that since. Probably related to my current problem, but I'm not sure how at this point...3. I have not tried the flooded start procedure yet, but I will now that you've mentioned it. My battery hates me right now.4. I have an old school timing light - I need to get an inductive type light - mine has the cheapo spring that goes between the plug and wire...
Dennis and Brian,
I follow you regarding the pressure vs psi and armature corrosion. If I understand correctly, my old pump may not be delivering enough volume to hit the 34 psi minimum, regardless of what the FPCU is telling it to do. I don't have access to tools that would show waveform, but I was already considering getting a fuel pressure gauge. If I tee a gauge between the fuel filter and fuel rail and measure pressure while cranking (with the FPCU bypassed), this should tell me if I'm hitting the 34 psi minimum, yes? Will this test accomplish the same thing as the waveform test? i.e. my pump is too worn to push the volume required by FPCU?
I guess my next question is: If the pump cannot push the volume required to hit 34 psi at cranking will the ECU (or some other factor) keep the car from starting (via no spark or some other method)? So far, it's clear to me that my FP needs to be replaced, and undetermined about the FPCU, but I'm wondering if the FP alone is the cause (or COULD be the sole cause) of the no start.
Thanks for your patience and experience,Tom
