95lstegman wrote:2 things i'd like to put on the table for you:1) i believe i heard something about the DSM turbos spinning the wrong way, or maybe it was that the inlet for the turbine was on the "wrong side" if you get what i mean, so that it wouldn't fit almost at all for us RWD SR folk. i have no interest in this as i know exactly what i want, but i thought this was why we can't use the very nice EVO3 and EVO8 16G turbos.2) having the outlet to the WG on the turbine housing seems like a bad idea to me; it will cause turbulence, of course, and i would want my turbulence a bit farther away from the turbine itself. i do like how the neck for the WG is perpendicular to flow. i can see this helping keep the wastegate shut longer thanks to the Venturi effect accross it. but i'd want it farther from my turbine wheel, that's all.
where do you think an internal actuator is? it opens and closes just as this one would...turbulence would not be an issue. And as far as the turbo mounting up wrong...I have no clue where you're coming from on that one. Then technically dsm users wouldn't be able to use gt variants such as 2871r, 3071, 3076, 30r...when we can use those bottom mount too just in a t2 flange..or a custom such as full race. Mainly I posted this looking for people that might know of someone thinking along the same lines as me or might know someone making a manifold that would use this. I'm either getting a used hks 3037 in the future, going with screamer pipe external wg modification or trying out this idea. Basically I know it would work ...it's very simple. As soon as I sell some more stuff I'm going to work with a guy who does welding for Oak Ridge Labs in building a long tube bottom mount manifold...I won't run into clearance issues ...so I can go crazy with length....did you ever see the blue SPEC car that was at some of the Formula D events? I've kinda been wondering though when length outweighs performance on runner length (especially in the case of remote mount turbo systems) I'm guessing as long as the runners are long it's fine..but when the charge pipe becomes lengthy you lose that benefit...I dunno someone elaborate on this.
