You have 2 options...
$1200 GT2871r or 3071R T2
or
$300 holset HY35, T3 mani, and external gate.
Both will spool about the same and end up costing about the same if you can get a good mani for around $500.
I have a friend making over 400whp in a B13 sentra with a HY35 on his SR20 and it is very responsive.
there are pros and cons to both setups but the Holset is rebuildable and the system will have room to grow if you go top mount.
BTW, when did FP quite selling the 20G for $5xx.00?? That is the best deal out there for a proven 400whp turbo but you were going to be doing some custom work to make it work and definately not using the oem mani. I'm putting a big 16g on a SR20 right now for a autocross setup.
