FoxMarketing »
https://forums.nicoclub.com/foxmarketing-u53291.html
Sun Jan 14, 2007 10:17 am
I have the stock hood on the car now, ZPI took that shot with the hood off to show off the custom turbo kit I have.
I am waiting on the aftermarket clutch from Comp to be made so I can really stomp on it. In a rolling start out of first gear, you step on it, the tires just roast, it is very suprising how much power this little car can make.
ZPI told me they had 15psi running to it and the motor held the power no problem. The clutch couldn't handle the power at all and they told me the clutch would explode if we run a stock clutch. They backed the boost down to 7psi so I could drive it home from Louisville on Tuesday. Once the new clutch is in the car, you will all see dyno number. I know at 15psi it will put down 270hp, no problem their at all. With displacement of the motor and some basic engineering you can figure out how much power something is going to make. I just don't throw number out their if it can't be done, what is the point of that really. You just end up looking like a dumbass and you don't know what you are talking about. All about creditablity in this and in life.
Just go to StreetFire.net and type in Versa and you can see the video of it. You can hear the clutch slipping a bit when you mass the gas, oh well, it will get fixed.
