swolpoppa wrote:just bought a 2004 Infiniti G35 coupe, when leaving for work this morning, having car parked in garage over night, ran across water leak spot on the ground from the car, is this something i need to worry about and take to dealership service right away? ive seen water spots inder cars from AC running but this is a pretty good size..
Take note of the coolant level in the plastic tank. Also fill the window washer tank but don't use it for a couple of days.
Recheck both after a couple of days. If you don't discover the source & it still happens then check the clamps on your radiator hoses. Try to avoid using the A/C while your checking.
Telcoman
