found two leaks, what are they?
1990 300zx
Car: 1990 nissan 300zx na
my z has a strong smell of gasoline when i drive, and it has terrible mpg. tonight after work i decided to tighten all 20 fuel clamps, unfortunately the smell was still there when i drove. I decided to take a look underneath the car and found two leaks.
This is the first leak that i found near the passenger side in the front.
http://i974.photobucket.com/albums/ae22 ... 8eefa9.jpg
The second leak i found was closer to the drivers side here.
Any idea what these two leaks are from? help would be greatly appreciated, thanks in advance
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Those are your tension rod bushings leaking.
1990 300zx
So you think they're both the tensioner rod bushings?
I thought they both looked like different leaks
nissanfreak12
Car: 92 300zx 2+2 TT
1990 300zx wrote:So you think they're both the tensioner rod bushings?
The leak could also be the power steering return line. If its on the passenger side, very likely. Tension rods do have a liquid in the bushing.
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Touch the fluid, if it feels thick and sticky, it's the ten rod bushings.
1990 300zx
I will first thing in the morning, and i'll write back. thanks
1990 300zx
sorry about the delay, it is thick and sticky. you must be right, tension rod bushings
