found this in my oil pan.
Uncle Dat
Car: 96 240sx, 78 280Z
i was removing my oil pan to do the gasket and I found this. What is this anyway and where it came from anyway? Just some broken plastic pieces. Image
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Looks like timing chain guides. Time to pull the front apart.
Uncle Dat
I assumed you meant pulling the front apart just to check? I did a search on NICO with the write up and it said you don't need the guides.
billyinse
Car: 1990 240 sx
from what i undertand if you dont have the guides your chain can eventualy wear throught the metal or it can weakent the chain.....if you think about it why would nissan put it on there if you didnt need it ...dont be lazy or cheap and just replace it
SxMachine
Car: Im on a horse
Uncle Dat wrote:I assumed you meant pulling the front apart just to check? I did a search on NICO with the write up and it said you don't need the guides.
Really dude?? Get the the guides, thats a pretty crucial part of your motor.
Uncle Dat
Yea...that was a stupid question. Now I just need to find infos on how to do this and let's the party begin.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
They are talking about the upper chain guides.
locoluna825
Car: 90 240sx coupe
lol i found a hand full of that s*** in my oil pan. but it was from my old guides. i already had a new one put in, that is After the chain ate into something cuasing my oil to mix with water. I wouldnt let that go so easily. I agree with everyone else put a new timing chain assembly in before it ends up doing somthing worse.
