Found some hardline just hanging around. Help
smokey240sx
I was adjusting my coilovers and found some stuff just hanging around. I have no clue where they go. I have a redtop sr20.
what suppose to go in here?
Blown240sx
Car: 1996 240sx
What year is your car?
Could be a hicus pump line
or emissions if you have a 96 240sx since mine had the emissions stuff located in the back of the car.
smokey240sx
I have a 92
smokey240sx
I have a 92 without hicas
Rican_Nick
smokey..
its nothing to worry about.. someone bypassed the clutch dampener and did not remove it.
its a common thing for many 240 guys to do to get better pedal feel.. along with its a ***** to bleed the clutch hydrolics with the loop in place.
Rican_Nick
also the last picture is just a drain tube.. its supposed to vent out like it is.. but someone did not put it under the bolt head when they put the transmission back on.
smokey240sx
thank you. I'll sleep much better tonight.
