DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Aug 10, 2005 4:13 pm
I wonder if there is any way to confirm the HG being the problem. You do not want to tear into it unless you're certain.The head can be removed with the engine in the car. Keep in mind you'll be lifting 50 lbs up from the alignment pins and out of the bay. I recall that even with the tensioner removed there is not enough slack to get the chain over the cam sprockets. The slack-side guide has to be removed as well. You may be able to unbolt the cam caps and rotate the cam upward (lowering the sprockets) to get more clearance, but you'll still have to devise a way to keep tension against the crank, or you could jump time and not even realize it.In the grand scheme of things, removing the front cover is not that much more work.
