Found our sunroof problem!
J30tman
I was bored on thanksgiving night and thought I would tackle my sunroof issue. My sunroof would go up and down just fine. When I tried to move it back it would just drop and not go back. I would then hit the button and it would go back to rest in its original spot. It sounded like the motor was working fine but it wasn't pushing the roof back. So, I took the switch panel down and saw the sunroof motor. I then pulled the three black phillip screws out and lowered the motor so I could access it. I couldn't remove it completely cause the plug was too far back in the headliner. I put an allen wrench in the spot where you manually close/open the roof and gave it a spin. It really didn't take much effort. I thought this was kinda weird because it wasn't spining the motor. I took the nut off that was on the other side of that allen bolt (need to flatten the washer under it first)and the three gold phillip screws to remove the cover. To my surprise it has a built in slipper clutch. Thats why it was so easy to spin. I decided to clean the clutch up and reassemble it. I made sure to tighten that nut tighter so the clutch didn't slip so easy. After I got it together I tried the sunroof and WOW, it works!
I have had the car two years and it never worked for me. I hope some of you can use these directions to repair your sunroof.
salemonkey
i am alitlle confused as if your sunroof would work some or not at all. maybe you can be alittle more clear to me, so it would open but not close, or it would not work at all and you can just hear it try and open
J30tman
salemonkey wrote:i am alitlle confused as if your sunroof would work some or not at all. maybe you can be alittle more clear to me, so it would open but not close, or it would not work at all and you can just hear it try and open
My sunroof would go up and down just fine. It wouldn't go back at all. The motor was working it just wouldn't push the sunroof back.
salemonkey
oh i see, ya i think mine is broke, it acts like it wants to movie it but sounds very sad and weak. but doesnt seem to move anything
littlewillie
Modified by littlewillie at 10:36 PM 12/23/2007
J30tman
salemonkey wrote:oh i see, ya i think mine is broke, it acts like it wants to movie it but sounds very sad and weak. but doesnt seem to move anything
Thats how mine sounded. It tried to go but wouldn't. Its very easy to get apart. You might want to take a look before you say its no good.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Here is an article on that fix http://www.nicoclub.com/articles.php?id=215858
J30tman
That is i
Gerardjg wrote:Here is an article on that fix http://www.nicoclub.com/articles.php?id=215858
that is exactly it.
littlewillie
