Onslaught31 »
https://forums.nicoclub.com/onslaught31-u66050.html
Sun Jun 17, 2007 10:30 am
First thing is, the price is definitely not too good to be true. Actually it seems possibly a tad bit high for the mileage (but that's comparing it to Florida prices, which might be different). That's no big deal. As for the title/registration/whatever being commercial, shouldn't be much of a problem since the carfax says it was only driven 15k a year on average.
As for quality, yes, the '03 was the worst year by comparison, but that doesn't mean the car will evaporate or the engine will fall out or anything. It just means it isn't as refined, they launched it that year, and then fixed the bugs with the next model. That's how all car models work. And the "bugs" are nothing more than little annoyances. I've never heard of engine, transmission, or other heavy duty mechanical work needing to be done on any '03 with decent mileage (under 150k). I make it a point to never buy a used car without taking it to a mechanic I can trust to have them check it out. The problem though, if you're buying from a dealership they probably won't let you.
Here's a rundown of things you can check yourself when test driving the car:
1. Test all electronics. Blinkers, horn, CD player, Navigation (if included), power seats, power windows, A/C, etc.2. While car is on, open hood and listen from the outside. Should be no clicking, hard humming, etc. Should sound like an engine, smooth and even. A rule of thumb I use is that in a performance car, you should be able to listen closely and hear the pistons fire individually, making a rythym. If you aren't hearing a steady rythym, something's wrong. If you can't hear at the engine, listen at the exhaust.3. Take it on the road. Little things will tell you about the cars history. For instance, how good are the brakes? If brakes are shot, who knows how the car must have been driven? Same thing with alignment, if it's off, that's something to note too.4. Keep an eye on the transmission. Press the gas pedal to a certain point and leave it exactly in that spot for a few seconds. If you don't change amount of pressure on the pedal, then the transmission should shift nearly flawlessly through the gears since you're accelerating at a constant rate. Any jolts, slips, lagging, or over-revving is a bad sign for the transmission. Also test transmission when parked, press brake pedal firmly, and put it in drive, then reverse, then park, then neutral (for example), and see if the car jolts or makes any noises. Shouldn't be able to feel a thing if the brake pedal is pressed hard.
If the car feels good after all that, it's probably a safe bet. Still have a mechanic check it out, some dealers even offer a 3 day return policy for example, plenty of time to have a mechanic check it out and return it if something is wrong.
G35 is much more fun than a Honda, but keep in mind, performance cars are moody: they will require more maintenance and upkeep.
Good luck!
