Found LSD, will it fit! Help!
Bob22b
I found a LSD on I think a 91? 240sx. It had those 4 lug 7 spoke alloys on it, and I don't know how else to determine the year. The car has 161k miles on it. WIll this differential work in my 98 240sx? Is it worth pursuing on a car with so many miles?
If this diff will bolt into my car, give me the details so I can go nab it right away! :D
Thanks
themadscientist
S13 diff into an S14, no go.
Bob22b
Dah... O well, I guess one of my s13 friends is in luck!
themadscientist
can't hurt to slide under both cars and check though. I am pretty sure the front mounting ears are different but it's worth confirming with a peek under the cars.
trsilvias13
yes the s13 lsd will fit all u need to do is swap the back half cover of the diff to the s14 one becuase it 6bolts instead of the 4 bolt like the s13. im goi to do it this weekend, if u are in sf u can see
