Found lots of insulation(hood) on the ground this morning
miata007
Car: 2009 Cube 6sp, 2005 G35 sedan
Recently, my Y33 started to have an engine oil leak. So I have been checking underneath the car for oil leak regularly and found a lot of insulation material from the hood being chewed off by mice. I then opened the hood and found maybe 1 sq ft area of the insulation is gone. I took a quick look at the hoses and wires. They seem to be ok. My car is parked in my driveway in front of the house. I live near the levee(river) so there are lots of field mice around. Does anybody have a way to avoid this from happening?
007
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Rex
Car: None
miata007 wrote:Recently, my Y33 started to have an engine oil leak. So I have been checking underneath the car for oil leak regularly and found a lot of insulation material from the hood being chewed off by mice. I then opened the hood and found maybe 1 sq ft area of the insulation is gone. I took a quick look at the hoses and wires. They seem to be ok. My car is parked in my driveway in front of the house. I live near the levee(river) so there are lots of field mice around. Does anybody have a way to avoid this from happening?
007
Well, I would suggest putting a cat under the hood ... but we've heard what happens when one gets under there .
See if the local hardware guy has any siuggestions for field mice in an area where cats/dogs could get at any poison/traps.
goody90q45
Car: 1992 Infiniti Q45 (sold)
I haven't laughed this hard in a long time.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Leave the hood open.
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Use a good ol' mouse trap and cut his darn head off....
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
my friend got a brandnew motor from chipmonks nesting in his motor siezed up and insurance bought him a brand new 15K 3.0 ltr for his 2000 A6.Home Depot sells poison sticks for killingBut there is a better ptoduct (pro grade) they are little blue blocks of poison that are like "Big Mac's to rodents.
nab911
Car: 93 Nissan 240SX SE
What if he doesn't like Big Macs? I dont....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
nab911 wrote:What if he doesn't like Big Macs? I dont....
He'll obviously live longer.
jamesmost
maxnix wrote:He'll obviously live longer.
i hate fast food , but every few monthes get that craving for a Big Mac or some other s**t like that.get one really tasty. then sick as hell.
miata007
Going to work this morning, I again check my car. This time more insulation on the ground and on top of that, 2 1-in long hoses labeled "left" and "right". I am not sure what kind of hoses they are. They are not the think rubbery kind used for oil or water that I know. I guess they must be hose for some electrical wires. Damn it! Two nights in a row.
Tonite, I am going to clean up my third garage space and put my Q in there. It's going to be alot of work. Or the Q can take the spot of my 92 Pathfinder instead depending on time and space.
007
miata007
By the way, Big Mac sounds good to me. I am going to stop by Walmart and get some of those green block Big Mac. Thanks for the help!
007
Rex
Car: None
miata007 wrote:Going to work this morning, I again check my car. This time more insulation on the ground and on top of that, 2 1-in long hoses labeled "left" and "right". I am not sure what kind of hoses they are. They are not the think rubbery kind used for oil or water that I know. I guess they must be hose for some electrical wires. Damn it! Two nights in a row.
007
The hoses would have me concerned, I might not even drive it until I figured that on out .
PoorManQ45
Just put rat poison on the plenum. Don't worry about cats getting at it. If they do, then they deserve to die
rasrx7
Car: 95 q45
91 President
94 Q45
03 Xterra
92 240sx hatch
93 240sx cionvertible
91 240 sx coupe
74 260z
73 240z
79 280zx
70 510 sedan
71 510 sedan
maybe its possible to use those ultrasonic sound emitting things that are supposed to scare them away from like plants..maybe you can use that...or like the one for dogs and cats...that way you dont have to deal with poison all over the place...especially if kids are around alot...
miata007
Anyway, the problem has gotten worse. Couple days later after I started this thread, while I was entering the driveway of my house the car started shaking. The engine idle was going up/down (+/- 200 rpm). I started inspecting the the engine and removed the chewed off hood insulation materials. In the process, i found couple wires (1 to 2 inches long) broken on both ends on the engine. Then I found a cable chewed off on one end. The other end connects to a connector with four signals. The cable was wrapped with a bicycle tire tube matterial. I am not sure where that cable goes to since it's on the back of the engine underneath the plenum I think, someplace very hard to see. I am planning to take some pics and post it here to see if it helps.
While the engine is running in "PARK", I checked all the electronics/switches, displays, lights, and .... in the car and everything works. (?????) There is one assumption I have is the cable connector. It looks like all 4 signals are tie together it is probably a ground signals or a power. I tried measuring it with a DVM but the reading was zero. I will need a hand from someone(my brother) to make better measurement. I hope I don't have to take out the plenum to get access to it. If I do, I am thinking about checking/replacing the ks, injectors, spark plugs, coils, MAF, and TB.
007
kimrober
Car: 1996 Q45t, 2002 Q45
Damn..... your Q must be really tasty to mice's taste... good luck man..
Rex
Car: None
Wow, I'm very sorry to hear about this. I would be rather concerned, not knowing what was damaged and knowing it would idle sans those wires .
I hope you can diagnose this and rid yourself of these pests.
qsiguy
Car: 1994 Infiniti Q45 Turbo
doubt it's gonna help where you park, they are probably living in there now. Strategic placement of rat poison under the hood. Yummy
Q451990
Maybe some pictures would help?
Heath
miata007
Yup! I am going post some pics this weekend when I get a chance to take it and figure out how to post. At my work, one of my co-worker's dad has a car like mine (97). I will ask if his dad will let me remove the engine cover and let me trace where those wires go. Will keep you guys posted.
In addition, I am going to get one of does pdf format repair manual on ebay. I think it's about $10-$12 shipped. Hope it has the info.
007
