Found...Infiniti Indy Car Engines
Inuyama
Car: V&H XR1200
I found these last week at a shop I used to work in. They have been in storage since around 2005 and were complete from air box to pumps. There was one first gen, five second gen, and one second gen fresh off the dyno and never installed. One of the engines was Eddie Cheever's Pikes Peak Winner the only Infiniti to win in the IRL. Just a little bit of history I thought was pretty cool.
PapaSmurf2k3
Site Admin
That is pretty effin sweet, but as is denoted on the valve cover... its spelled "Infiniti" :)
simmode1
Car: Red '95 S14
I'll trade you a non-running KA for one... :naughty:
Inuyama
Car: V&H XR1200
Thanks!
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
Someone needs to put one in an s13 and race the local hooligans on the Appalachian Downhill.
sbird1
Car: 2006 BMW 325i
That's a pretty sweet find. Is the shop willing to sell them any of them?
Razi
Car: Moo
Can I have one? :)
Inuyama
Car: V&H XR1200
They are all gone. I have the new one :)
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Inuyama wrote:They are all gone. I have the new one :)
So you have one... more info on exactly what it is?
I have an S13 Hatch shell this could sit in.
Inuyama
Car: V&H XR1200
General Engine Info:
Infiniti VRH35ADE/612E Indy
DOHC 32-Valve V8 with aluminum-alloy block and heads; molybdenum coated pistons
90-degree cyl angle
3.5-liter
650 hp @ 10,700 rpm
320 ft-lbs @ 10,400 rpm
Bore x Stroke:
93 x 64.39 mm
Bore Spacing:
112 mm
Compression Ratio:
13.8:1
Sequential multi-point fuel injection
DOHC 4-valves-per-cylinder, titanium valves
Crankshaft:
180 degree-Billet Steel
Connecting Rods:
Machined Alloy Steel
Lubrication System:
Multi-stage dry sump
Oil Capacity:
12.0 quarts
Max. Engine Speed:
10,700 rpm
Fuel:
Methanol
Top Speed:
225+ mph
It is new with a Magneti-Marelli ECU, Carbon battery, ECU, spark box, and a spare set of spark plugs. The engine cost over 100k when it was built.
Warped161
Car: 90 s13 the never ending project
holy crap! and how much did you pay?
Inuyama
Car: V&H XR1200
Less than that :chuckle: It is also probably the last new example of this engine :)
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Pics or it didn't happen. What's it going into?
Inuyama
Car: V&H XR1200
OK, In my storage pod while refinishing the garage floor. They have all been sold, except the one I'm keeping. No plans at this time.
Ace2cool
Ace2cool wrote: What's it going into?
Inuyama
Car: V&H XR1200
2 are going into a street car (have no idea what), 3 are going to Bonneville, 1 on display, 1 getting parted out, and 1 I'm keeping in storage.
SeanDean
Car: V8S13, 528i, 328is racecar
Could you please email me about the last engine you have?
sdeanl------gmail---com
I have a V8 Nissan project that I originally intended to use one of these engines but ended up with a 4.1 Q45 swap and I'd like to finish the car the way I originally intended.
If you are dead set on keeping the engine then could you let me know where some more would be available, (I'm sure whoever you bought them form can point you in the right direction)
I think I can make you a reasonable offer.
Cheers,
-Sean
flohtingPoint
Car: 2004 Z16 Corvette Z06
simmode1 wrote:I'll trade you a non-running KA for one... :naughty:
It'd last you 15-20 hrs before needing a rebuild. The rebuild would cost you more than the average person pays for medical school.
simmode1
Car: Red '95 S14
^^^Oh I'm certain... Kinda like those high strung Robello built N/A SOHC KA's with 300+hp.
Inuyama
Car: V&H XR1200
SeanDean wrote:Could you please email me about the last engine you have?
Cheers,
-Sean
Done, It's the new one with the Magnetti Marelli ECU, filter, plugs, carbon battery tray, and ECU tray. It would run fine detuned on Gasoline. To detune it would cost around 5k
SeanDean
I checked my email, nothing in the inbox or spam folder yet.
-Sean
