found cheap LSD
doctortomek1
Car: S14
I found a OBX LSD for $370 is it any good, I don't have a grand for the other ones, and I'll probably need to change my diff so I could afford the OBX.
How hard is it to change a diff for a LSD ?
gumby74
I know of 2 people that run the OBX helical.One is on an SR'd hatch, the other on an n/a KA. Both are going on almost 2 years installed with no problems or issues of any kind.If I would not have gotten my S15 helical for a little bit less, I would be rocking the OBX unit myself.As far as the install goes, if you are mechanically inclined at all, it can be swapped in a few hours. BUT you will need to have the gear mesh verified by a shop unless you have the equipment to do it yourself.Overall though, I rank it at a 3 out of 5 in difficulty.
