Are the ball joints listed for the Z32 or the Q?captainluigi wrote:found the ball joint @ rockauto.com a spicer part #50523129 @ $25.79. federal-mogul @ napa @ $32.32. ordering bushings from mynismo.com
Just to clarify,You are talking about the FRONT lower control arms,correct? This is a great savings idea,wonder how much $ and effort it would be to install bushings/ball joints?captainluigi wrote:the part ap. is 1990-1996 z32. nismo bushings-$43.00 shipped. ball joints. spicer #505-1239 $63.00 shipped. controll arm from dlr. $600.n shipped. all quotes are both sides. $106.v/s $600.
If you have, and understand the procedure used to R&R the 240 ball joint then do just the same for your car. Furthermore after you have removed the control arm from the car you can't help be see how to proceed if you have the least bit of mechanical knowhow. I have changed the the ball joints on the 240 after going thru what you just did with the NAPA guys. Nissan does not sell the ball only, for the 240 and I just couldn't see paying what they wanted for the control arm w/ball, which was quite pricey, given a choice. Some of the guys on here seem to have a vested interest in promoting those outrageous prices for those OEM parts. IOM going to OEM is for when you have absolutely no other choice or if prices are comparable and maybe.captainluigi wrote:yes, the fr. lwr. cont. arm bushing & balll joint. yes only one bj per side held in w/circlip. federal-mogul & dana/spicer manufac. this joint. perhaps others as well. rockauto.com has the spicer, a U.S. of A. prod. your local napa or whatever will have a moog joint & a federal mogul joint. before some texan chimes in that moog is federal mogul i am aware of that. however there are two grades of joint. chat w/your local parts supplier if you want that explained to you. SEARCH for a sticky by KENRIK, he replaced l.c.a.b & t.rod on a 240. though not EXACTLY the same you will see his methodology is descriptive enouugh. i too would like to hear from anyone who has performed this operation on there Q. if there is anyone with a CONSTUCTIVE critique of planed approach i would greatly appreaciate hearing about. i for one am still learning and have not yet reached the nirvana state of all knowing.
Nice to meet you. Trico Marine is still around doing the same thing I suppose. They might even be bigger. Bollinger is definitely bigger. I think 13 yards now. They build big boats and barges for sea service plus repair same. I'm in their yards frequently since I work for a labor company that supplies the welders etc. Mexicans for the most part. Good workers and nice guys. To me at least and we get along well.captainluigi wrote:hi RAP, yeah it seems all pretty simple & not even that labor intensive. have re-built many U.S built suspensions & was just curious of any hidden glitches that might be waiting. on another note, i see you live in Lockport La. years ago i operated crew boats owned by a co. in Houma called TRICO & often visited the Bolinger shipyards. nothing like 4 screamin Detroit 12V71 @ 1000 H.P. each. do not miss that but do miss the food of south Louisiana.
LES BON TEMPS ROULE!
I have the same question and need; is there someone out there that give the part numbers and who to get them from? REAJJY NEED HELP!!1995Q45havoc wrote:my balljoint went out on my 95 Q can i replace it with a diffrent balljoint or am i looking at purchasing a whole new arm?
