Found an old alarm under my dash-can i use?
Post all your Nissan electronics, car audio and stereo questions here!
vancouverbc
Car: 1991 240sx
i found two boxes under my dash which are blinking . one says black widow. there is a grey wire with a sensor and a black and red wire dangling that appear to be cut from something. The red wire is hot. I wonder if i could salvage the alarms. i bought the car used. there is a relay with a thick yellow wire going to it that is just suspended by the wire. there is a diode on the relay. I'm assuming this might have flashed the light when the alarm went off.
A_Rivers
Car: 1998 Honda CRV, 1996 Yamaha FZR600
Hey VanC, one of the boxes you found is the alarms "Brain" and the other box is probably a shock sensor. The relay is more than likely a starter kill relay, which will cut power to the starter when the alarm is active. Here try this and keep me posted. http://www.blackwidowsecurity.com/ Get me some model numbers and i will try to help you out.
