The wire hangs down around the oil filter then goes to a connector just above the oil filter that is secured somehow then it joins the rest of the wiring.
I have looked through el.pdf from index of /FSM/Altima/2001/ but I can't seem to figure out what this is exactly.
Only code a (aside from the o2 sensor code) was the knock sensor but that one doesn't pop up every time I pull codes.
Any ideas where that loose end is supposed to go?
Thanks in advanced
Andrew
