Eswift »
https://forums.nicoclub.com/eswift-u367.html
Tue Sep 30, 2003 9:09 am
timing belt.
i am unaware of any upper link issues.
if there is any rust, you will see it on front swaybar first. also around sunroof. also at the main side body weld underneath the doors. Mine is a 94, which has lived in the salt belt, and only has the sway bar rust. these are simply the common locations.
hard to tell during the day, but check for intermittent headlights (headlight relay) and intermittent interior lights (dimmer).
note how it shifts, transmission is arguably more of a problem than on Q's. check transmission fluid, color, smell, froth, etc.
96 model will be OBDII...ewww.
everything else is similar with other cars...uneven tire wear, exhaust quality/quantity-give that stuff a look.
injectors fail here and there, mostly due to these reformed fuels up north..
bose radio can be a problem, turn it on, check for proper operation and any pops or crackles.
other than that, I have had mine for over two years and nothing besides preventative maint. or stuff I could fix myself.
be prepared for a combined MPG of around 21-23.
t comes with spoiler, smaller sway bars, hicas rear wheel steering, BBS wheels.
