found a 90 model 2.4 block will it work on my 85 head?????
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
dsmboi_ebay
Car: 1985 720 nissan 2.4L
Hey everyone i have an 85 720 with the 2.4L engine.. it overheated a while back and cracked the block... i already got a new head and all i need is anouther block i belive i found one that would work but its a 1990 it only has the 4 plug head i was wondering if swopping heads would work and if all the stuff of my 85 block will fit on my 90 block????? someone please get back to me on this subject....
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
WELCOME TO THE FORUM!!
Z24The Z24 is a 2.4 L (2389 cc) engine produced from 1983 through August 1989. A fuel injected version was produced starting in April 1985. It produces 103 hp (77 kW).
Applications:
Datsun Truck Nissan Hardbody Truck Nissan Pathfinder Nissan Van Note: All Z20, Z22 and Z24 engines were known as NAPS-Z (NAPZ or NAPEZ) engines. NAPS for Nissan Anti-Pollution System. All NAPZ motors had dual sparkplugs per cylinder except the pre-82 versions. However all NAPZ engines sold in California reportedly had dual plug heads regardless of the year.
The fuel injected version referenced above was denoted as the Z24i (Throttle Body Fuel Injection) and was first available in the Nissan Model 720 ST pickup during the 1986 crossover year to the (1986.5) D21 Hardbody and was later replaced by the KA24E engine. Beside fuel injection, a significant change for the Z24i was the addition of an optical crank angle sensor in the distributor rather than a vacuum advance and ignition module. This allowed for more precise engine management for the fuel injection system.
The General Specifications for the Z24 are:
Engine Type: - Inline 4 cylinder 4 Stroke Engine Displacement - 2389 cc (146.8 c.i.) Bore x Stroke:- 89.0 × 96.0 mm (3.50 x 3.78 in) Compression Ratio:- 8.3 : 1
Power Ratings were:
- Z24 -
Years - 1984 - 1986 Power - 103 hp (77 kW) @ 4800 rpm Torque - 134 ft·lbf (182 N·m) @ 2800 rpm
- z24i -
Years - 1986 - 1987 Power - 103 hp (77 kW) @ 4800 rpm Torque - 134 ft·lbf (182 N·m) @ 2800 rpm Years - 1988 - 1989 Power - 106 hp (79 kW) @ 4800 rpm Torque - 137 ft·lbf (186 N·m) @ 2400 rpm
Here is the info on the KA....I don't think you can make them work.
http://en.wikipedia.org/wiki/Nissan_KA_engine
dsmboi_ebay
IM NOT GANA LIE THE MORE I LOOK AT TRHE BLOCK THE MOR I THINK IT WILL WORK BUT THE THING IS I HAVEN BOUGHT THE BLOCK YET SO I CANT ACTUALLY TRY IT... IF I DO MY HOME WORK OR IF SOMEONE GIVES ME A SOLID REASON WHY IT WONT WORK WHERE DO YOU THINK I CAN GET A 85 YM BLOCK BECAUSE I REALLY WANT TO GET THIS PROJECT GOING...
PEZi
well i dunno if it will work for sure but i'm wondering the same thing... i plan on doing the opposite of you and putting a 90's head on my 85 block... this will be after i do pistons so that i won't destroy the head!
dsmboi_ebay
NOW SEE SO IT BOLTS UP AND THE CHAIN WORKS BUT THE PISTONS DONT CLEAR OR WHAT???? JUST TRYING TO UNDERSTAN WHAT YOU MEAN BY..... "THIS WILL BE AFTER I DO PISTONS SO THAT I WON'T DESTROY THE HEAD!"
PEZi
i'm doing high compression pistons and the z24 head won't hold the power... everything should clear fine
dsmboi_ebay
SO... BY THE WAY IT SOUNDS IF I KEEP THE 90 MODEL BLOCK STOCK THE HEAD WILL BOLT ON BUT I DID THINK THERE WAS A DIFFERENCE IN THE DISTRIBUTER BOLT DOWN..... IS THERE???? I NEED TO LOOK AT THAT BLOCK AGAIN I GUESS... BUT IF YOU KNOW THE ANSWER LET ME KNOW I WONT BE ABLE TO LOOK AT THE BLOCK TILL THIS WEEKEND.
I REALLY NEED TO TAKE SOME PIX OF THIS TRUCK AND POST THEM EVERYONE WOULD GET A KICK OUT OF THE MURDER JOB (FLAT BLACK PAINT) I DID TO IT...
ilovemymini
Car: 1984/720/dually convert to single
he sent the spec to you for the block ..would have to be same specs as other block.. i have a spare block napz 1985.. i maybe going to need it now ive had same problem overheat long story but radiator was loose after i finnaly finished my 84 project i put it on the road voila 2 weeks later radiator let go into the fan i thought it was power steering pump and then the engine died although i dont think block is cracked id be upset if it is,,because it was just rebuilt b4 i bought the truck,, needed everything else and i mean everything has been replaced.the door locks and ignition switch factory key set..except paint interior wiring found a like brand new front yoke in salvage yard when i got the (wrong)shortbed..so icouldnt pass it up(yoke) and shaft.i have been googling machine shops i saw same engine allready built for 2100$ plus 250 to 400 shipping and like three year 30,000 warranty but want you need is info for your setup take alook @ this site http://www.jsamotors.com/files...c.htm or @ http://www.nissantech.com go to the left side click on nissan online mechanic maybe more help
PEZi
have you noticed mine?
i did it all flat black including tails corners and signals
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
wouldn't a truck from 1990 be a D21 with KA24e?
dsmboi_ebay
BREAD BOX- SEE IM A NOOB WHEN IT COMES TO THIS I KNOW THE 90 IS FUEL INJUCTED AND ALL THAT BUT SEE IT IS ONLY THE BLOCK AND THE BLOCK ALONE I NEED AND MY HEAD FROM MY 85 WILL GO ON IT BUT... IM NOT SHURE ABOUT THE DISTRIBUTER AND OIL PUMP SITUATION...
PEZI303- I HAD SEEN YOURS MINE IS JUST A SINGLE CAB THOUGH AND I LOWERED MINE MUCH LIKE YOURS BUT I THINK IM LOWER I HAVE A TOTAL OF -4 INCHES IT IS A LITTLE BUMPY BUT CORNERS AND DRIFTS LIKE DREAM... WONDERING HOW DID YOU FIND THE BLACK CORNERS AND TAILS OR DID YOU DO IT YOURSELF...???
ILOVEMYMINI- THANX FOR THE LINKS ON MOTOR SHOPS AND TEK HELP IV SEEN THE SPECS AND I BELIEVE THE MOTOR BLOCK WILL WORK BUT IM STILL WORRIED THAT THE DISTRIBUTER AND OILPUMP IS DIFFERENT... BUT I WISH YOU DIDNT NEED YOUR BLOCK I WOULD SO BUY IT FROM YOU
YOU WERE TALKING ABOUT YOUR OVERHEATING PROBLEM SEE MINE WAS A BELT BROKE ON A ONE HR TRIP I DIDNT HEAR THE BELT BRAKE AND THAT BELT RUNS MY ALTANATOR & WATERPUMP SO WHEN THE BATTERY DIED IT DIDNT MOVE THE TEMP GAUDGE SO I NEVER KNEW WHAT WAS GOING ON TILL THE TRUCK DIED... WHEN I FOUND OUT THAT THE HEAD WAS WORPED I HAD IT FIXED AND PUT IT ALL BACK TOGETHER HOPING THAT WAS ALL TO MY PROBLEMS WHEN I ADDED WATER TO THE RADIATOR I HURD GURGLING THROUGH THE INTAKE I ROLED THE MOTOR OVER WITH NO PLUGS IN IT AND IT SHOT WATER OUT THE CYLENDERS BASICALLY TELLING ME THE BLOCK IS CRACKED... SO IF YOUR GANA DO THE MOTOR MIGHT AS WELL HAVE THE BLOCK CHECKED SO YOU DONT END UP LIKE ME...
breadbox
89 Koop
84 720 4x4KC
Well if you grab the harness and ecu too. Wire that sucker up. KA24e's are surprisingly fun motors.
PEZi
dsmboi_ebay wrote:PEZI303- I HAD SEEN YOURS MINE IS JUST A SINGLE CAB THOUGH AND I LOWERED MINE MUCH LIKE YOURS BUT I THINK IM LOWER I HAVE A TOTAL OF -4 INCHES IT IS A LITTLE BUMPY BUT CORNERS AND DRIFTS LIKE DREAM... WONDERING HOW DID YOU FIND THE BLACK CORNERS AND TAILS OR DID YOU DO IT YOURSELF...???
with VHT nighshades!
yep... i've heard as long as it bolts up properly its much more suitable for the extra power i'll make!
breadbox
89 Koop
84 720 4x4KC
also, your Name is odd.
DSM"boy"_ebay
I have been driving my old GS-t lately, gave it to mom but driving it til I do my motor swap. Are you a DSM kinda guy?
dsmboi_ebay
yes very much a dsm guy i hav a 96 mitsu eclipse with a 420no turbo engign but i built it up and put a aftermarket turbo on it this car is my money pit but when i get done it will be an easy 13 second and street legal car but yes my dsm is my favorite ... i started out as a honda guy but even though learned alot about hondas i kept getting arrested in them so idk but iv only been pulled over once in my mitsu and that was for chacing a guy down in a m3 for flicking me off ... i cought him lol
dsmboi_ebay
so pezi303 if a 90 bolts onto a 85 then an 85 should bolt onto a 90.....
PEZi
yes indeed... i'm just not 100% sure it does bolt up... i've only heard one person say it will but none that say it won't
dsmboi_ebay
the only thing is the block to transmission and block to mounts.... but im so proud this conversation has given us all knowlage lol..... every one let me know if you can find out about the mounts and transmission if they line up ???? its a Z24 transmission and a k20 block..... let me know
dsmboi_ebay
OKAY SO FAR EVERY ONE WE HAVE FOUND OUT THAT THE Z24 HEAD WILL FIT ON A KA20 BLOCK BUY.... THE BLOCK WILL NOT BOLT UP TO A STOCK 720 PICKUP transmission ALSOW THE MOTOR MOUNTS WONT LINE UP THE MOTOR MOUNT ISSUE CAN BE FIC BUY JUS SIMPLI WELDING THE NEW ONES DOWN BUT IF YOU WANA DO THIS SWAP YOUR GANA NEED A transmission SO I WANT EVERYONE TO KNOW IM KEEPING THE Z24 FOR NOW AND I REALLY REALLY NEED A Z24 BLOCK PLEASE DO ALL U CAN TO HELP I NEED THIS TRUCK BACK ON THE ROAD AND OFF THE JACK STANDS.....
breadbox
89 Koop
84 720 4x4KC
just so we are clear it is a z24 block and a ka24e block that are almost the same.
KA20 doesn't exist. K20 is rsx motor.
I got the GSt in trade for my 99civic SI. Found out later that it has a 6bolt swap, so no crankwalk for me. Not sure what turbo is on it, but I hate it. I know nothing bout dsms, Always like the way eclipses looked.
Open the local phone book and see if there is one in a yard near you. These trucks got abused alot so you might find one.
dsmboi_ebay
yes everyone major in the ka20 my bas and typo its supposed ka24 lawl
dsmboi_ebay
evaryone post pics of there 720 trucks i wana see what the compitition looks like!!!
Kyle_Bryan
Car: 1986 nissan D21 pickup
i have a 1986 nissan pickup and im also trying to find out if my head will fit a k24 block i think its a k24 block anyways lol its out of a 1992 nissan its also a carb motor valve corer says 2400 series i belive im kinda a noob at the nissan stuff i really need to know if my head will fit this block and bolt up to my trans can i get some help?
Dat_82_720
Car: '82 Datsun 720
Z22 Auto
z24-head-m-block-valve-cover-timing-cha ... 56881.html
sorry dude....just scraped a Z24 block that you coulda picked up CHEAP
Return to “Datsun 720”
