95-96 240SX - $5000 (Unless I can find one in cosmetically good condition with a blown engine and transmission for less)
S13 blacktop SR20DET with install and all necessary belts, fluids, intake and a/f + boost guages - $4200
Greddy 3 inch DP - $170ish?
Apex'i N1 single exhaust - $420
Greddy Profec B - $330
Clutch of some sort - $350
Apex'i S-AFC - $340
Walbro 255 fuel pump - $120
Miscellaneous shipping / problems with SR20DET - $1000
Total: $11,760
Is there any market for the stock KA engine and exhaust to cut the cost down some?
What kind of oil filter does the SR20DET use and where can they be purchased?
Is the S-AFC necessary at this point, or do you not need that until you get injectors?
What clutch is recommended?
Instead of going with the Apex'i N1 exhaust, would it be just as beneficial if I had a local exhaust shop make a custom 3 inch exhaust?
Thanks.
