The moneys not the problem...even if I have to save for a bit to get them. I've got fairly good income and vendor discounts! Do you happen to have a pic of those works on that car?ddgsxr504 wrote: The question is can you afford it??
They will fit the car but will look sunken with 50mm over fenders, thats the same offset I have on my Zenki and I don't run any type of over fenders.AJ1356 wrote:Sorry for the tread whoring but these would fit zerothread?id=226822
adrians_s13 wrote:progress pics are necessary
At least. Thanks Nismofly!nismofly wrote:something like 17x9.5 +0 front, 18x11 -11 rear
do you happen to have a pic/link of this?nismofly wrote:that would give the same specs as 17x9 +14 on stock fenders, i figure thatd look pretty nice
JE Import's RB26 powered S13 hatch is gorgeous. Saw it in Turbo magazine. I thought 19's would have been out of place on it but man was I wrong. Those Volks look so sexy on it.jspec603 wrote:That looks killer. So thats a 17x9+14 huh. Hmmm. So you think that wheel in a Zero offset would work? Also, I was just taking lunch and was flipping through the new Turbo Mag. They've got JE Import Performance's car rockin 19" Volks. Those are a little too big for me, but that's the look I am going for, just in an 18" wheel instead. Unfortunatly turbo has not updated the website for the pics, but I got this off of JEIP's page...sorry its so small.
thatd take a LOT more than a little camberwhiterps13 wrote:Those would definately work. They might take a little camber to keep under the fenders, but run a stretched tire and everything will be a gravy.
As I stated before, I've got alot planned for this car. Tubbing the fronts actually happens to be one of those things. My other problem is the bodykit mixed with NH roads. I need to beable to drive this car too. IMO a 17" wheel slammed would put this car way to close to the pavement. That is why I feel an 18" all around would be better for this application. I do however understand where you are coming from and do see your POV. On a non kitted s13 chassie your setup would work great. The 19's...too big.nismofly wrote:the wheels in that pic are actually 17x9 +15, but 1mm doesnt make a noticeable difference
2nd, 17s in front will let you get nice and low, notice how the 19s on that car mean the front has to sit way up even though its nearly tucking tire, that car also probably has tubbed fenders to clear that setup
like i said, 17x9.5 front, 18x11 rear, thats something to aim for
Perfect!!jspec603 wrote:Don't know if this is exactly the look I am going for, but size wise? 18x10 -9 and 18x11 -14
Im planning on itnismofly wrote:
throw like a 40mm spacer on your rota's, with stock fenders,
