Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Nov 14, 2003 12:33 pm
forging is not "cutting" things out, its using a ton of pressure in a die to beat something into shape(i think this is what you meant). monoblock forging is using a single block of alluminum and, using different forging peices, beating it with great pressure into the shape you want.
forging will align grain structure(as noted) and will allow the use of less materials for the same weight, assuming materials are the same(IE alluminum). A cast wheel and a forged wheel wont make a difference is they're engineered so they are the same strength, forging allows you to use less material sometimes, resulting in less weight.
-chetNote: there can be forging problems, such as incorrect dies and things that can cause imperfections.
