esahuque »
https://forums.nicoclub.com/esahuque-u20709.html
Thu Aug 20, 2009 12:20 pm
I popped my 3rd stock motor about 2 month's ago and finally bit the bullet and went forged 8.6:1 supertech pistons and arp head studs. motor runs great, love the way it feels. I was going to get tuned this Tuesday. Now I have oil gushing out the lower timing cover right by the alternator bracket. at first it was just lightly dripping but now its pretty much a steady flow. Now i have the pleasure of draining the oil and coolant, pulling the valve cover, distributor, upper timing cover, loosening the motor mounts, dropping the sway bar, lifting the motor up, dropping the oil pan, disconnecting all the coolant lines and radiator hoses, removing the crank pulley, then finally removing the lower timing cover. then of course everything in reverse order.
End Rant/
