vulcanrush »
https://forums.nicoclub.com/vulcanrush-u157160.html
Fri May 28, 2010 12:25 pm
this is from eric hsu over at cosworth:
True Horsepower
What kind of power can the stock internals of an '03 Nissan 350Z engine handle? I'm looking into forced induction and would like to keep the stock internals, if possible. Is there a turbo kit you would prefer, and can you recommend a good tuner near Chicago?
-Chad Sweitzer
Shannon, IL
There are two types of stock internal horsepower ratings. One is based in reality and the other is what you see in some dumb-a** post on the forums. The lamest is when a forum member posts a thread with some outrageous number using stock internals, titled: "652whp/630tq @ 22psi-highest horsepower red '06 350z stock-internal VQ35DE on C16 fuel east of the Mississippi, south of the Mason Dixon line, in the 402 area code." Reliable, usable power limits are always lower than the one or two dyno passes a car can be tuned to put down before blowing up. A stock VQ35 is good for a max of about 400 hp at the wheels when tuned properly, if you want to be able to drive it daily or beat the crap out of it at the track. Any more than 400 whp and you stand a chance of breaking parts. Shops can build "one-run wonders" to make 600+ stock-block whp on race fuel, but it's just plain stupid to assume that a connecting rod won't exit the side of its block if you drive it like that at the track. I'm not too familiar with shops in the Chicago area, but Sound Performance comes to mind-their 1,280whp 350Z runs 9s on a stock six-speed transmission.
different engine, similar question, right?
500hp is a lot to ask of stock internals. i'm currently rebuilding a vg30dett, which imo, is much stronger than a vq35de or vq37vhr (iron block vs aluminum block) and i'll probably push 400, nothing too crazy.
