Ford Guy trying to help with 300ZX water pump
mustang7065
Car: 1995 300ZX NON-Turbo
I have a 300ZX that needs a water pump replaced, I am a fair machanic but as I look at the front of the motor it seems that H-balancer must come off along with most of the frontof the moter. As I think back, this is the time for timing belt and water pump change. As you can see I am not a import guy but learning. Can some one help me along with this.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Yepp, most of the front stuff has to come off like the radiator + hoses, front water hard pipes, CAS, crank pulley (harmonic balancer), all the belts, and then the timing covers.
It's one of those "while you're in there jobs", go ahead and replace the belt, tensioner, idlers, water pump, cam/crank seals, VTC cover o-rings, and thermostat. You can also replace the bypass hoses and idler studs if you have the cash.
Here's a video tutorial on it:
http://www.youtube.com/watch?v=cjU_G7GKdEM‎.html/
