VitaminT wrote:I believe that the compressor only comes in one trim and flows 44lbs/min. The option is to get either a .64 or .86 A/R on the turbine.
Someone please correct me if I am wrong.
Also we may need to start a new thread. I feel like we are thread jacking on the FP turbo.
i've seen it advertised with 2 different compressor wheel trims, 42 and 58 (or was it 48 and 52?). they flow 39 and 44lbs/min respectively according to the site i found the info on.
and to the person that asked about the A/F on 50lb injectors and 93 octane, it was nicely between 11.5-12:1 pretty much all the way along the graph. i have no clue his fuel pressure settings or injector duty cycle at that level but i'm sure it's pushing the fuel system to it's outer limits. but the wideband doesn't normally lie;)
as for the bigT28, i've seen it make about 325whp but that was pushing it pretty hard.
