For your perfectionists.. carpet replacement is cheap
1992Q45A
$159.00 for the entire rear carpeting.. Didn't get a quote on the front carpeting, but this isn't expensive at all... nice way to restore your interior if you are hardcore about your Q..
It's OEM from the dealer, so exact fit is assured.
WOW!!!
I have often considered replacing mine... Wonder what the front costs....
1992Q45A
I dunno, but your previous suggestion quoted me that price. I was shocked at how cheap it was. I can't imagine the front being that much, if the rear is that cheap.
That would really go a long way to restoring your car to near new condiiton, in terms of interior.
Nice to know they still sell this kind of stuff for our ancient rides :)
1992Q45A
Damn I need someone who charges cheap labor..
I guess to reinstall the carpet, the seats wil have to be removed. At this point I should install the dynamat to all doors, and the floorboards.
Keep in mind the dynomat is heavy.
I have a mechanic I trust to work on my Q, lives in Surprise and does top-notch work, cheaply.
1992Q45A
hitman,
how much wieght adding do you think is in this bulk pack?
http://www.sonicelectronix.com...=1726
The 10455 bulk kit includes 9 sheets of Dynamat Xtreme, for a total of about 36 square feet (a car door requires about 5 square feet). Designed especially for high-temperature areas and high sound pressure level situations, Dynamat Xtreme offers four times the damping power of Original Dynamat, thanks to its energy-reflective aluminum layer.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Wow.. Thats cheap.. the rear ash trays are $62 each :eek: :mad: :eek:
Did you get a quote from Joe??
Id go with the dynamat while you have it all out...
Ry - Dynamat weighs approx 3 lbs per 4 square feet, so you can do the math...
1992Q45A
27 pounds....
You had me thinking 100+
I was thinking it weighed more too...
Of course, you'll need almost 3 boxes just to do the floor of the Q, and another 2 boxes if you do the trunk and doors...
1992Q45A
I'll hit the gym and remove the spare tire/jack/stuff... :)
Worthless anyway with the bigger brakes.. couldnt use it if i wanted to..
I saw a neeto combo pack at Infiniti dealer..
had the green slime and a compressor for blowing the tire up
1992Q45A
hmm, you sure???????????????????
assuming 5 square feet with 4 doors.. that would be 20.. leaving 16 feet...
not sure how much it would take to do the floorboards...
I have no spare / jack either.
Removed them to "justify" the 18" wheels... I know, I know... but hey, it made ME feel better. :)
Green slime is worthless - Better to drop the $ on AAA or some other roadside assist.
The ad you quoted says 2 boxes to do the entire floor of a "normal" size car.
1992Q45A
Yea but it has a compressor... so you can bandaid the wound and inflate the tire.. I agreee its worthless on its own, because generally the tire is too flat..
I've used ti successfully a few times.. it's saved my a$$, but other times it's been friggin worthless.. I thought having the compressor might give it an edge... Roadside is nice but takes forever
1992Q45A
It did.. Where, not seeing it???
"But if weights not an issue, then definately line your car in dynamat. I suggest if you plan on laying your entire car with dynamat, buy two bulk packs."
Customer review...
Not sure how accurate it is, as the customer owns a Civic. :beatfreak
:D
1992Q45A
Maybe this would be better for the floorboards
Dynamat 21205 Extreme Liner $US59.00
One 24" x 36" x 0.5" (1) 609mm x 914mm x 13mm* piece of ExtremelinerExtremeliner is the ultimate low-frequency attenuator. Extremeliner is a four-part composite barrier consisting of 1/8 inch layer of neoprene, 15 mils of acoustic lead barrier, 1/4 inch layer of high efficiency acoustic foam and a 3 mil urethane top facing. Extremeliner works anywhere on your vehicle's floor and firewall for the ultimate barrier against road and engine noise.
Appearance: 4-Layer Acoustical foam barrier with black urethane surfaceThickness: 0.392 inchesMass: 1.5 lb./ft2Temperature Resistance Range: -54C to +149C (-65F to +300F)Chemical Resistance: Resistant to water and mineral oilsAdhesive Peel Strength: 74.81 N/min on cold steelFire Classification: Meets FMVSS 302Handling And Application: The material must be at room temperature before handling and applicationStorage Information: Temperature Range: 32F to 86FNumber of Sheets in Stack:200 MaximumThis material must be stored horizontally in its wrapping
11205 Weight: 15.00 lbs
Oh yea, that.. They also have one for the hood, supposedly reduces underhood heat.. although the Q already has insulation there, so not sure what good it would do, or where to install it
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
I've had different people tell me the underhood mat is for engine fires, the plastic keepers melt and it drops down. Just my .02
Mr1der
weight reduction with 4000 pound plus cars is a funny idea:D
So is increasing hp to 400. :)
1992Q45A
As long as those ls400 bastards can supercharge their low tech v8, I won't be satisfied until we can do ours as well.
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
I used two bulk packs plus six loose sheets of Xtreme in my 98 F150 regular short cab.
That's a lot of Dynamat in a small space.
By the time you did the Q roof, quarters, floor, two layers on the doors (inside under the door panel, and inside of the outer door skin) you'd have many, many bulk packs in the car.
That stuff is addictive, I'm telling you now. Everywhere you place it makes the untreated areas louder. Next thing you know the interior looks like a big inside-out baked potato.
It's an OCD person's dream, for everyone else, a nightmare.
1992Q45A
I was thinking of the doors/floorboards only..
Now you've given me even more places to put it
You're gonna need to run 8 lbs of boost just to haul around the Dynomat. :D
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
Hey guys here are some tips I’ve gotten from SQ experts on sound deadning. They recommend at least 100.00 sq ft ,the more the better. Degreasing and de-waxing the metal, the most important step in sound deadening – though a lot of times neglected
The most noticeable location is to cover the wheel wells. This is where a lot of the road noise comes in from and the difference at highway speeds is dramatic! Cars with big sub systems are going to rattle ...even with multiple layers of mat in the "usual" spots....so concentrate on the areas that are in need WITHOUT the steteo vibrations first....then chase rattles afterwards.
Use if you can afford Dynamat's Dynaplate. Expensive as hell, but it only weighs 0.17 lbs/sq ft.You can call Dynamat and speak to Kevin Mutters. He’ll be very informative. RAAMmat ( good stuff and reasonably priced) weighs in at 0.4 and Dynamat Xtreme is 0.45. I believe the second-lightest damping sheet on the market is Cascade Audio VMAX, (awesome stuff) which weighs 0.23 lbs/sq ft.
Hope it helps.
D.
Good info!
I had good luck shooting the inside of my prior car's wheelwells with some heavily rubberized undercoating... Quieted down those fat, sticky tires. :)
1992Q45A
Thanks for the info, very appreciated.
I was checking out the dynaplate, not too expensive..
I guess the deal is with dynamat, is it gets expensive..
As heavy stated the OCD sets in and before you know you have 5 bulk packs dynaplate and everything else :)
I'm confused on what I should use and where I should use it. Apparently the products also go on top of each other, like applying dynamat extreme then a layer of dynaplate..
Definetely want to take this to someone who has experience dealing with this.
squeefoo
1999 Infiniti I30
I'm going to find some just for the doors, hopefully somebody around here will sell eaches. Then I can have fun putting it on through the holes. ( Hey man, what happened to your arms??!!)
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
squeefoo wrote:I'm going to find some just for the doors, hopefully somebody around here will sell eaches. Then I can have fun putting it on through the holes. ( Hey man, what happened to your arms??!!)
Too true, you'll look like a cat attacked you before it's overwith. I have a lanky kid that comes in the shop whose arms are long & skinny as a flagpole. He's helped me out several times.
The degreasing is sooo important. 2nd that.
But even after it's placed in the area, getting every square inch stuck to the surface is where the time really racks up.
Once it's stuck........it's on for good.
I'll post a pic of my truck with all interior removed when I can find it.
