teddy wrote:So I'm pretty much fed up with the all of the factory electronics. It's just one headache after another and I'm very interested in getting a Haltech. I've looked over many stand alones and think the e6x suits my needs the best. I was hoping those of you who had some experience could give some insight.
I dont have experience with the haltech system but most of the standalone systems on the market are similar in terms of parts and certain functions, so I could provide a little insight.
Quote »1. Keep the factory tps or use the haltech? Any advantages to either aside from extra dough out of my pocket?[/quote]Keep the factory TPS theirs no reason to purchase the haltech tps as it does the exact same thing. The only reason I would see to use it is if they dont allow you to use the factory one.
Quote »2. Coolant temp sensor. It says it fits 95% of vehicles. Will it screw right in or am I going to have to retap it? I'm assuming the stock location is the best place. [/quote]Is their any possibility of using the stock coolant sensor? I checked the haltech installation guide and checked the sensor section, and just so you know it says it uses a 3/8 NPT Coolant Temp Sensor its a GM sensor. That is a BIG SENSOR. Just to give you an idea my Megasquirt system is setup for GM sensors but I have the option of changing to whatever sensor I want as long as I know the resistance values. Anyways I tried to see if I can fit the 3/8 NPT coolant sensor and their was too much of a possibility of it not fitting and damaging the coolant port of the intake manifold. But the common rule is to get the sensor as close to the head as possible for accurate reading. If you can see if you can use the stock coolant sensor I can give you the resistant values at certain temps. To give you can idea of big the GM CTS and Nissan CTS are here are some pics.
Quote »3. I want to ditch the stock coilpacks in favor of possibly some ls1 coils with built in ignitors. Anyone have anything better they can recommend?[/quote]LS1 coils are probably the best coils you can find in todays automotive market. Each LS1 coil is actually rated to 1000hp.
Quote »4. The idle controller...is it necessary. Yay or nay?[/quote]Are you refering to the stock idle control setup? If so sure why not, you could delete it all but you'd be left with a high idle usually around 1200-1500rpms.
Quote »5. Last question. The new harness should have wires to connect to the lower harness? So everything will function through the haltech.[/quote]Well the lower harness is kind of seperate, some of the things like the speedo are wired straight to the gauge cluster etc etc through the maze of wires that run along the fender.
Quote »Thanks for any input ahead of time. I'm open to suggestions. [/quote]
