240sxHitman »
https://forums.nicoclub.com/240sxhitman-u16795.html
Mon Apr 03, 2006 6:49 am
Got this from the Option Imports website.
First debuted in the 2005 Tokyo Auto Salon A'PEXi AFC NEO Fuel Computer is now available at OptionImports.com Limited quantity in stock, so get yours before it's gone!
Compact "Piggy-Back" Fuel Management Computer (+50%/-50%). Unit incorporates both the SAFC and the VAFC. New "Easy" (8-Point) & "Pro" (16 Point) Modes. New Color FED Display. Inverting "anti-glare" screen allowing view from all angles.
Monitor Mode - RPM, Throttle, Battery Voltage, Correction %, Air Flow %, Pressure (Kpa), Karmann, VTEC
Setting Mode - Air Map, Air Map Graph, Throttle Point, Deceleration Air, VTEC Control, VTEC Unmatch
Etc. Mode - Model Select, Mode Select, Car Select, Sensor Select, Analog Scale, Warning Set, Display Set, Sensor Check
* Some vehicles may not display all parameters listed above. Parameters vary according to vehicle model.
