MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Mon Jan 03, 2005 10:18 pm
Hey guys,
I'm planning on building my engine this summer to be capable of about 330 whp @ ~17 psi of boost.
Anyway, I'm pretty nervous about being able to pass emissions after the engine is completely rebuilt with lower compression pistons, oversized valves, different cams, and a completely different fuel system....I'll be running MSD 50 lb/hr fuel injectors, a JWT ECU, and a Z32 MAFS. I may, if money allows, also have an S-AFC II to tweak the a/f ratios and make it run better/less rich than the JWT tune, which could be VERY useful in trying to pass emissions...but I'm not sure yet.
I JUST squeaked through emissions this past spring with my car running 370 cc injectors, stock motor, stock MAFS and a JWT ECU, but it took some creative tinkering to make it pass (very low fuel pressure, very retarded timing, a lot of methanol in the gas tank, etc). I'm worried that changing to even larger fuel injectors, a completely different MAFS, and an even more conservatively tuned ECU (read: rich) that it'll be impossible for me to pass emissions in a year and a half (yeah it's a while away, but I can't just ignore it). After it's rebuilt my car may run beautifully and somewhat cleanly at WOT under a lot of boost, but that's not the way they test it...they test it in lower rpms, probably 2500 or so, and not under boost....and I forget if they did it when the car was idling or when it was moving...but I'm pretty sure it's when the car is idling and in neutral, which means if I'm not running very lean and clean at idle, I'm sorta screwed.
So, for those of you making 300+ RWHP, how many of you have actually passed emissions?
1) What's your fuel management/timing setup?
2) What state are you from/what is the emissions testing procedure?
3) OBD 1 or OBD2? (I'm OBD2, but UNFORTUNATELY, I'm a 1995, so in Connecticut, they put a probe in the tail-pipe...for those OBD2 cars 1996 and above, as long as there's no CEL's, they pass...lucky ducks).
4) If you have the actual copy of the test, what were the numbers?
I know Jeff from ka-t.org is making 340 whp on a fully built KA24DE-T, but he's a 97 OBD2 which means he doesn't need to have a probe to sensor his exhaust gasses...
Thanks in advance,
Marc
