float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Aug 30, 2006 12:05 pm
Stock mani should spool slightly quicker, but I don't know how it is going to flow up top. To it's defense though, it does have paired runners (4-2-1) even if they aren't equal length. The SSAC mani is an equal length, but the runners aren't paired like they are in the stocker. IMHO though, the runners are long enough that I wouldn't be too concerned about reversion anyway. The SSAC mani should flow more, it's MUCH easier to install and remove as opposed to the stock mani, and if you ever decide to jump up to a T28, you won't have to worry about grinding on the turbo housing or mani to get it to clear.
If you're sticking with those injectors and a slight MAFS upgrade, and a chipped ECU, I'd stick with the stocker. Anything more, I'd ditch it and get the SSAC unit. I've been running it daily for a year w/o a problem.
