tramp_drift240 »
https://forums.nicoclub.com/tramp-drift240-u50915.html
Sun Mar 22, 2009 6:39 pm
alright. previously, my motor was leaking oil from the oil pan, and coolant from the freeze plugs.
totalled my car, pulled the motor to reuse. fresh rebuild with 300ish miles on it.
while the motor was out, i replaced the brass plugs with steel plugs, VERY good seal. also, new pan gasket, VERY good seal. then swapped the motor in.
its running in the new motor, will run like ol' times once i swap out the fouled spark plugs tomorrow. BUT, i've run into a problem im not sure how to handle...
apparently, the lower timing cover, or something in that area, is leaking coolant. after a little driving, looking under the car, theres probably...a drip of coolant every 3 or 4 seconds.
AND, i believe theres very very fresh looking oil coming from directly under my header. fairly sure between the block and head.
now, i got fired from my job, and im trying to move back to VA as soon as possible so i can get another job, start making money, etc. ORIGINALLY, going to drive back next week after my five lug install, new brakes and rotors, Work CR's and new tires.
im in a predicament with what i found today though. should i drive it with some leaking, and handle the situation later? or should i dive right back into the FRESH swap, pull off the manifolds, valve cover, timing covers and the head. and replace/repair what needs repaired now.
i havent driven in so long. and now im making monthly insurance payments, so i cant chill without a job for too long. i dont know what i should do.
advice is greatly needed.
