For those who experince CD ERR on the radio/center console screen
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
This isnt really a fix but rather I would like you to fully look at the problem before you go and give 200+ bucks to fix something that may or may not be broken.
qship96
Car: 1996 Infiniti Q45
That certainly is one cause of the problem.....unfortunatly they never issued a TSB nor apology for using Sony 10 disc changers which proved highly unreliable and silently replaced by the 6 disc Clarion, which I have had zero issues with {sure do miss having 10 CD`s loaded up though}
The only thing Sony does really well in my book are the XBR series trinitron televisions
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
C'mon.....what about BetaMax?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:That certainly is one cause of the problem.....unfortunatly they never issued a TSB nor apology for using Sony 10 disc changers which proved highly unreliable and silently replaced by the 6 disc Clarion, which I have had zero issues with {sure do miss having 10 CD`s loaded up though}
The 10 CD-ROM players are not unreliable, but do need to be refurbished every 10 years or so. The reason the Clarion became available is the 10 CD Sony was discontinued.
ERR is an indicated failure to read the disc for whatever reason.
Infinitiguy19
And when I get the harness to get my CD changer working and the changer need to be repaired do any of you know if they have a direct phone number for CD changer repairs?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Dealer or Sony only that I know.
qship96
I remember hearing Sony no longer supports the 10 disc changers....no more parts or servicing.
Not sure Joe still stocks the Clarion substitute either { was a smoking deal for less than 150 when I bought it years ago}
Someone here is hopefully enjoying the remaining parts from the ole Sony!!
captainluigi
Car: 1996 q45t
Clarion is now discontinued. However I found a USA-SPEC brand 6 cd changer a plug & play unit for the 96Q. I did have to re-fab the mount but no biggie. A better option may be an IPOD.
96Qowner
Car: 1996 Q45
My Sony 10-disc changer is still working great at 204,000 and 12 years.
It's a little touchy about CD surface quality though, as is most older CD technology.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Cold weather definitely affects my 10 disc Sony changer. When the car warms up I get less errors. I am actually going to burn a CD at the slowest speed possible to see if that makes a difference and also try 2 different brands of media.
Infinitiguy19
What for mat do they have to be on the CD? If you could give me a step by step explanation that would be great.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
I'm having a similar issue with the 6-CD Bose changer in my MDX. The dealer wanted $600 to fix it and recommended just trying to find another unit elsewhere to replace it.
It's intermittent. If the CD decided to play at all, you'd better thank your lucky stars and don't even thinking about switching the disc to another one.
